firmware
  • bomberi
    • 107
    firmware
    Thank you for help, I need IR ADVC2225i firmware. I have E602 Error and i want to change the HDD.
  • teckat
    • 16083
    Re: firmware
    Sub code xXxX is 👂
    • bomberi
      • 107
      Re: firmware
      thank you, sub code is E602-0102.
      • JPiek
        • Oct 2014
        • 435
        Re: firmware
        E602 0102 00 Title File system error on the HDD
        Description: The file system failed to be initialized properly at startup
        Remedy :
        1. Turn OFF and then ON the main power
        2. Press (user mode key) => (2, 8) => (user mode key),Select
        the following to enter 4: [1]:CHK-TYPE = 4, and select and
        execute the following: [2]:HD-CHECK = 1; and then turn OFF
        and ON the power.
        3. Start in safe mode to format the HDD (all the data in the
        HDD is erased)
        4. Replace the HDD
        Johan
        • bomberi
          • 107
          Re: firmware
          Thanks, when i replace the hdd i don't have the firmware To download it.
          • bomberi
            • 107
            Re: firmware
            Please Can some one send me the systeme for canon IR ADV 2225i .
            • teckat
              • 16083
              Re: firmware
              why would u put in a New HDD without having firmware
              put back old HDD
              and perform posted below
              Select
              [1]:
              CHK-TYPE = 4, and select and execute the following:
              and ON the power.
              report back
              • copier tech
                • 8195
                Re: firmware
                We can supply the latest Printer firmware & Photocopier firmware. Click Here For - Ricoh, Konica Minolta, Kyocera, Lexmark or Canon Firmware -
                • bomberi
                  • 107
                  Re: firmware
                  thanks for your helps. I 've done what you say but now in the screen it makes always: "Starting please wait a moment"
