Print and copy are fine but recieved fax are very light
canon advir4235 receiving fax light copies
Re: canon advir4235 receiving fax light copies
________
This machine's fax function is compatible with ECM (Error Correction Mode). ECM corrects errors and distorted or poor quality fax transmissions that arise from line noise. It also enables you to send or receive high-quality faxes even if the condition of your telephone line is not ideal. (See "Enabling ECM Transmission.")
http://ug.oipsrv.net/USRMA-0132-zz-CS-enUS/contents/CS4251_settings150_enablingecmtransmission.html#ad func_133_01_h1_1
Enabling ECM Transmission**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
________��
hen the machine is receiving a fax. No problem printing, copying, scanning, or faxing out. Any ideas?Comment
Who\Where are faxes from ?
Coming from a fax printer or a copier ?
IMPORTANT
If you want to transmit using ECM, it is necessary that ECM Transmission be set in both the destination machine and this machine. This function does not operate unless ECM is set in both machines.)
If the other machine does not support ECM, this setting is ignored.
If transmission speed appears to be extremely slow, you may be able to speed up transmission time by turning ECM 'Off'.
Canon : PIXMA Manuals : MX490 series : Quality of Received Fax is Poor**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
IMPORTANT
Canon : PIXMA Manuals : MX490 series : Quality of Received Fax is PoorComment
