Hi are iR-ADV 8205 just started to have solid black line in the same area of the paper we have here is photo the line is near the top of the paper any help would be appreciated IMG_20180124_121524.jpg
Could be
Primary charging assembly
Clean the primary charging assembly. May be need a new corona.
Photosensitive drum cleaner unit
Check to make sure that there is no paper or foreign matter trapped in the cleaning blade assembly?
Remove the foreign matter, and clean the cleaning blade and the casing of the cleaner unit.
Also check the cleaning blade for scratches on the edge of the cleaning blade?
