Help solid line on paper on are iR-ADV 8205
  • QC91
    • Oct 2016
    • 91
    Hi are iR-ADV 8205 just started to have solid black line in the same area of the paper we have here is photo the line is near the top of the paper any help would be appreciated
  • kuby
    • Oct 2007
    • 1405
    Re: Help solid line on paper on are iR-ADV 8205
    Is the line when making copies thru the document feeder or the from the glass or printing from a computer?
    • QC91
      • Oct 2016
      • 91
      Hi, via computer PDF or test prints from the 8205 panel
      • kuby
        • Oct 2007
        • 1405
        Could be
        Primary charging assembly
        Clean the primary charging assembly. May be need a new corona.
        Photosensitive drum cleaner unit
        Check to make sure that there is no paper or foreign matter trapped in the cleaning blade assembly?
        Remove the foreign matter, and clean the cleaning blade and the casing of the cleaner unit.
        Also check the cleaning blade for scratches on the edge of the cleaning blade?
        • QC91
          • Oct 2016
          • 91
          Hi, we checked the Primary charging assembly it's clean have to look at the drum cleaner unit
          • QC91
            • Oct 2016
            • 91
            Hi, Thanks for all the help, we fixed it tons of toner stuck in the drum cleaning blade, and cleaning unit we also reversed the blade
            • kuby
              • Oct 2007
              • 1405
              Great glad to help.
