Canon Advance C5250 paper size not available
  • giogi
    Engineer senior
    • Jan 2016
    • 182
    #16
    Re: Canon Advance C5250 paper size not available
    sorry teckat
    could you make me a screen of this thing (in print drivers > under Output from Application)?
    thanks
    "Knowledge is a source, but unfortunately ignorance is a sea."
    • teckat
      • 16083
      #17
      Originally posted by giogi
      sorry teckat
      thanks
      Not sure u can set Custom Paper in this UFRII Driver ?
      Canon - Windows UFR II Printer Driver - User's Guide
      UFRII MANUAL
      Selecting the Appropriate Printer Driver
      Registering/Editing Custom Paper Types
        Originally posted by Joana
        I have a problem that from UFRII driver I cant print on custom size sheets. I register custom sheets on printer, but when printing cant change custom size from driver.
        Where I could try switching these options ON and OFF? Is it on driver or on printer?
        can you set it to " USE PRINTER SETTINGS " ?
        • Joana
          • Feb 2018
          • 14
          #19
          I have found throught windows settings>printers and scanners>then from printer list choose UFR driver>printer preferences and the you need to choose custom size and register your custom size.
          Then when you print something you will have an option of custom paper size.
          What a strange way to choose....
          • petermays
            • Mar 2017
            • 91
            #20
            hi
            this might be a stuiped question.
            have you changed the plain paper type to plain 2?
            check in the printer settings and see if the printer plain setting is set to what the paper tray is set to.
            maybe tray is set to plain 1 and printer setting is set to plain 2.
