Canon Advance C5250 paper size not available
  • apollo
    • Mar 2008
    • 191
    Hi all members
    I have weird issue if anyone has come across it on Canon Advance C5250.
    all firmware all up date also.
    Although all trays are set up correctly A4 Plain 1 (64-81g/m2) ever time customer prints
    MFD beebs and message displayed "The appropriate paper size A4, is not available. press Ok than prints.
    But this fault occurs also if you try to print PCL Config page or Fonts list from settings/registration, so I ruled out
    customer network and print drivers issues and settings.
    I have also checked on Canon Simms also, but nothing on this nature fault
    paper overide is on in printer settings, no joy
    also initialised printer setting under
    function settings
    printer--- printer settings etc....
    Also thanks in advance for any input cheers guys..
  • teckat
    • 16083
    Re: Canon Advance C5250 paper size not available
    Originally posted by apollo
    Hi all members
    function settings
    [ATTACH=CONFIG]38700[/ATTACH]
    in print drivers > under Output from Application---set to OFF
    example
    Printing from Adobe Acrobat >when [PS output from Application] is turned to "ON" or "Auto Adobe will print directly to the printer skipping the Canon Printer Driver.
    When [PS output from Application] is turned to "OFF" Adobe Acrobat PDF files will print through Canon Printer driver utilizing the Canon printing settings and allowing print jobs to print. with custom paper sizes.
    Probably does not apply in your case
    • apollo
      • Mar 2008
      • 191
      example
      Hi
      thanks for the reply
      but but this issue locally with copier if you print config page or font list
      • apollo
        • Mar 2008
        • 191
        example
        Hi
        may will try back up and do MN-CON clear and see
        • tech28
          • Jun 2013
          • 434
          Driver, get the newest one from Canon. Had one at a realtors office, every time they sent a print job, would beep and she would have to get up and hit the button for it to print. Had the generic Windows driver. Reloaded URFII driver from Canon, worked great. That was 3-4 months ago.
          • apollo
            • Mar 2008
            • 191
            Thanks for reply
            latest drivers installed while on site UFRII, but still same issue , get up press ok to print Lol
            • copier tech
              • 8169
              The poster states that this issue happens even when printing a config page so this rules out a driver issue.
              Have you checked that auto paper select for the printer option tab has all your trays tuned on/enabled?
              See attached pic, choose the printer (2nd one down) then highlight all trays, or leave any trays that have headed paper loaded unchecked to avoid printing onto that when the other trays with plain paper run out.
              Enabling Paper Drawer Auto Selection - Canon imageRUNNER ADVANCE C5255/C5250/C5240/C5240A/C5235A e-Manual
              • teckat
                • 16083
                [ATTACH=CONFIG]38706[/ATTACH]
                good point,
                • teckat
                  • 16083
                  Thanks for reply
                  what about Test Prints from service mode
                  • apollo
                    • Mar 2008
                    • 191
                    Will check this on Monday most probably someone played around with settings and will update on forum
                    "Teckat" yes PG test prints OK
                    • apollo
                      • Mar 2008
                      • 191
                      Morning All
                      back to customer
                      checked all trays for auto paper all on as per pic
                      connected my laptop locally with update UFRII drivers, on print auto paer select same issue load A4 paper,
                      if I select tray1 or tray2 on printer preference than prints fine.
                      also any meter reading, pcl config page etcc same message.
                      • apollo
                        • Mar 2008
                        • 191
                        Morning all
                        checked all setting for auto paper select all on as per pic
                        connected laptop locally UFRII drivers on auto paper select same issue.
                        if I select tray 1 or 2 on printer preferences than prints.
                        anything from copier PCL or meter readings or pcl font page, get same message appropriate paper size A$ not available
                        Rang Canon UK awaiting their call Lol
                        any further input appreciated
                        • apollo
                          • Mar 2008
                          • 191
                          Hi
                          Just an update had to initialize all data to factory in data management as per Canon UK
                          do back up first all customer settings add book network settins etc....
                          than
                          management setting
                          data management
                          erase all data/settings
                          took 30min
                          than I/p all data back
                          all working now
                          thanks Guys for all your input
                          • teckat
                            • 16083
                            Hi
                            than
                            management setting
                            data management
                            took 30min
                            all working now
                            Usual Canon Support---if they can't find it in a book > Initialize & Erase , get back to us in the Morning
                            • Joana
                              • Feb 2018
                              • 14
                              I have a problem that from UFRII driver I cant print on custom size sheets. I register custom sheets on printer, but when printing cant change custom size from driver.
                              Where I could try switching these options ON and OFF? Is it on driver or on printer?
                              example
