Received E602-513 (hard disk failure) power down machine, Fiery showing '00' prior to powering down. Upon repowering the machine, I received E748-2024 (Main Controller board 2 Access Errors), reseated Main controller PCBs 1 & 2, no joy... Fiery is not starting/powering on when restarting the main unit. Reseated DIMMS on both PCBs and reseated Fiery PCB on controller PCB 2, still no joy.
Something of note, main controller 2 did not have the two retention screws that hold it into the chassis when I went to removed it the first time (presumably from when the original dealer was installing the Fiery hardware). Wondering if this allowed the board to wiggle loose from the connector. Screws are in it now, not that it makes any difference at this point in time...
Any help would be appreciated.
