canon ir adv 6255
  • smiley
    • Aug 2008
    • 613
    canon ir adv 6255
    canon ir advance 6255 no power. when i turn on the machine theres no power led that turns on in control panel even the lcd. and when i check the pcbs at the back the ip main green led lights turns on. is there anything i need to check at power supply or at the ac drive? i check fuse at ac drive they are all have continuities. any body has expirience on this please help me.
    there is no glory without sacrifice
  • el nayo
    • el nayo
      Re: canon ir adv 6255
      saludos amigo, me paso un problema similar el detalle estaba en la main controler no hacia buen contacto las conecciones solo desconecte y conecte de nuevo. anteriormente ya la abian checado otro tecnico le faltaban unos tornillos y por lo mismo quedaba lebantada la placa y no hacia buen contacto suerte saludos
      • smiley
        • Aug 2008
        • 613
        thanks you. i will try to disconnect all connector and reconnect again i will update you if something happen. thanks.
        • smiley
          • Aug 2008
          • 613
          good day guys just an update on my problem. i replace the main controller and machine is now working.thanks for all the advice.
