Canon Ir3045 Faint Copy on Top side
  • netbaba2000
    • Jul 2014
    • 21
    Hi
    Please help me to solve this strange problem * as Subject )
    pc to print ----- ok
    copy mode ---- Fainted in top side
    scan mode ----- clear ok
    check parts.
    scanner ---- ok ( Pls see attached Image )
    transfer roller ---- ok
    developer cam pressure ----- ok
    please help me find out where is problem.
    Please attached Image Files...
  • roho
    • Mar 2009
    • 844
    Re: Canon Ir3045 Faint Copy on Top side
    Take the copyboard glass off and clean the optics if prints are fine.
    • hidius
      • Jun 2015
      • 128
      is this copying off the platen glass or from the ADF ?
      • netbaba2000
        • Jul 2014
        • 21
        hi
        optic is already clean. ( Scan is Clear )
        this sample scan file from platen glass.
        same Faint copy issue with ADF.
        Thx
        • copier tech
          • 8142
          If you do a PG 3 test print is this still faint?
          You have made no mention of the drum, looking at your sample i'd say this could be the issue.
          Remove & inspect the dev unit, do you have a even coating of toner?
          • netbaba2000
            • Jul 2014
            • 21
            Hi
            pls see PG 3 test Image
            drum have no issue because print is clear ( Already replace with good working canon same mode )
            and developer roller toner coating is even ( Already replace with good working canon same mode )
            but still same problem
            thx
            • Brian8506
              • 1664
              Looks like a toner problem to me. Is it OEM or generic. I've seen a certain generic toner cause that. The problem may begin to migrate further down the page.
              • dan7777
                • Dec 2012
                • 680
                Originally posted by netbaba2000
                Hi
                check parts.
                Could be transfer roller or toner dust on laser glass.
                • netbaba2000
                  • Jul 2014
                  • 21
                  Hi
                  yesterday i change transfer roller.
                  and same clean laser unit ( inside and outside )
                  there is no toner dust or any foreign particles on laser glass
                  • netbaba2000
                    • Jul 2014
                    • 21
                    Hi
                    on this moment i also think about toner. The last option change toner and cleanup DP Unit
                    reinstall new toner pack.
                    let us see hopefully problem would be solved.
                    if not i will be back soon
                    thx
                    • Brian8506
                      • 1664
                      Hi
                      thx
                      Vacuum dv unit. Then install empty bottle of toner and run a toner-s. This will empty the hopper. Then vacuum dv again completely and dry wipe dv cylinder. Install new toner and toner-s again
                      • copier tech
                        • 8142
                        Hi
                        thx
                        Looking at your PG 3 that too looks faint at one end so you can rule out the scanner. (Assuming you didnt scan this print sample on the copier!?)
                        Check the drum life, again from your PG 3 I would say you are not using a genuine Canon drum unit c-exv 11/12 ? How about toner genuine?
