Poor Color Prints on heavy paper
  • RHodg57
    • Dec 2013
    • 191
    IRADV C5030 Seems to be only on heavy paper. The samples shown are blue but it does the same with any color or black.
    I am thinking IT belt, fusing or transfer. Seems to be only one side of the page. Customer is far away so I was looking for
    some thoughts on it.kk2.pdf
    kk1.pdf
    The first image is on regular weight paper. The second on heavy paper.
    Changing the the paper setting to Heavy 2 made no difference.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Poor Color Prints on heavy paper
    Canon has never solved this problem.
    The IRA series will never print on heavy paper such as CLC or IP.
    I would stick the pdf remedy but I can't.it's only 6 MB
    • RHodg57
      • Dec 2013
      • 191
      I used the same paper on our machine here and it printed fine.
      I know there was a change at some point in the IT belt They went with
      a thinner belt, but I don't remember the reason.
      I did the heavy paper auto gradation adjustment and that made no difference.
      • zoraldinho
        • Mar 2008
        • 5007
        I can send you this bulletin via email.
        • mramlawi
          • Jul 2011
          • 838
          Always face this probelm with no soultion changed itb drum ,clear dc ,change everything and still same
          Distinguished road makes you jewel in rough
          • NorthW
            • Jul 2017
            • 55
            You can adjust secondary transfer settings for heavy paper in service mode, HV-TR, give that a try.
            • RHodg57
              • Dec 2013
              • 191
              i swapped out the ITB Assembly and the problem went away. Thanks for the suggestions!!
              • zoraldinho
                • Mar 2008
                • 5007
                Any time
                • mramlawi
                  • Jul 2011
                  • 838
                  If u can send it for me email will be thankful
                  • MunsterTech
                    • Sep 2014
                    • 381
                    hi
                    there is a bulletin about this on sims mottled effect on heavy paper, they have modified the springs behind the transfer roller secondary on the door, ill try and find the bulletin when i get home, quite a while ago as far as i remember.
                    • Canuck
                      Tech Specialist
                      • 1713
                      Old news...install new style transfer rolls, thin itb, roller holders, etc. Make sure paper is registered properly. Swapping itb fixed it you say....upgrade your itb assembly with mods then re-install it. Don't forget to tell machine it has new STYLE itb and rollers in service mode
