MF8540CDN unable to open RUI
  • copier tech
    • 8220
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: MF8540CDN unable to open RUI
    Can you print report to check correct network settings? Can you print at all? Any errors in history?
    Did you try with static ip?
    Enable HTTP communication?
    • copier tech
      • 8220
      Like I said above the machine will print fine, printing a configpage will show it has pulled the correct setting via DHCP.
      I connected my laptop directly with a crossovercable using a static IP but the same issue cant open the RUI.
