Imagepress 1135+. PG7 white dots
  • lilleputte
    • Jan 2013
    • 153
    [CQ] Imagepress 1135+. PG7 white dots
    Hi , i'm struggling with this 1135+.
    White dots on PG7.
    Actions so far
    1. Cleaned paper feed path from paper dust.
    2. Changed itb / primary transfer roller
    3. Inspected developer, drum , charging , fuser. (everything looks perfect)
    SBZC220 VER18022216080.pdf
    All ideas are welcome.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    Re: Imagepress 1135+. PG7 white dots
    Hi,
    Drum failure, developing system failure,
    laser exposure system failure.
    To me look's like scratches on the drum surface but you already check...
    • lilleputte
      • Jan 2013
      • 153
      Hi ,
      We will remove everything and deep clean the machine.
      I will return with a answer on Monday. Have a nice weekend
      • zoraldinho
        • Mar 2008
        • 5013
        Drum have A4 volume.Print full black on bigger size like A3 and check for dot pattern to find out if it's a drum or not.
        • teckat
          • 16083
          White dots on PG7.
          Actions so far
          [ATTACH]38958[/ATTACH]
          The white dots are caused in colder environments when the drum heater for the imagePRESS 1135/1125/1110 is not turned on.
          This can also occur if a new developer assembly is brought in from a cold environment and is installed without allowing the developer unit acclimatize to the room temperature.
          Resolution for this image quality issue is to turn on the drum heater or allow the new developer unit to reach room temperature prior to testing.
          Also_u already did this--disreguard��
          Replacing the Primary Transfer Roller (FC7-9326-000) should resolve the copy quality problem. (White Dots)
          The Primary Transfer Roller is called the Transfer Roller 1 in the Parts Catalog.
          The Transfer Roller 1 part number is FC7-9326-000.
          The estimated life of the part is 1,500,000 prints .
          • lilleputte
            • Jan 2013
            • 153
            Perfect , we did turn the heater on and then the white "dots" are gone .
            We did change the Primary Transfer Roller but with bad result ( still white dots )
            Thanks alot for awesome support
            • teckat
              • 16083
              St Patty.jpggo raibh maith agat
