canon ir3530 noise
  • garrycmsi
    • Jun 2015
    • 22
    canon ir3530 noise
    I have a canon ir3530 that has a high pitched squeal for about 3-4 seconds after paper exits. seems to be coming from in and around right door, I have checked the fans and the laser unit. any and all ideas would be very helpful thank you in advance.
  • copier tech
    • 8101
    Re: canon ir3530 noise
    Hi,
    This is the only known noise issue I could see.
    I have personally seen the exit rollers squeak like mad, a few drops of oil seems to resolve it.
    Measure against the noise from the waste toner drive.pdf
