help! ir-adv c5045
  • q555
    • May 2015
    • 81
    help! ir-adv c5045
    Can anyone know what the cause of this
    What i did
    1. i changed the drums, then it was ok, but after a week same problem again.
    2. i decided to change the processing unit but with the same drum assembly, and again it was ok, but after a couple of days, same problem again.
  • teckat
    • 16083
    Re: help! ir-adv c5045
    What i did
    Could be a grounding issue 😱
    • q555
      • May 2015
      • 81
      hi teckat,
      next time what will i do is,
      totally empty all toners and put new developing unit but i will still use the newly build drums, and lets see if it will still happen.
      • teckat
        • 16083
        hi teckat,
        Try booting up into diagnostic mode, (holding down buttons 2 and 4 for approximately 20 seconds while turning on machine)
        see what comes up ?
        is issue on glass scanning / or prints / or both
        • q555
          • May 2015
          • 81
          see what comes up ?
          hi teckat,
          i will try that.
          both teckat
          usually, it happens every morning, then once the machine printed around 100-200 copies, all prints will be okay.
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5018
            Is the machine in a cold environment overnight?
            • q555
              • May 2015
              • 81
              hi zoraldino,
              i also thought about that, but the environment is ok because this problem already occurs in many 5045 that we are handling.
              we just change drum assemblies to temporarily correct this problem.
              • copier tech
                • 8220
                Are you using compatible toner and/or drums?
                • q555
                  • May 2015
                  • 81
                  yes, we do use compatible toners and drums. all consumables are compatible.
                  • teckat
                    • 16083
                    OEM ---------note: many of these Canon OEM products fool Canon--market is flooded with them-easy to print fake labels.
                    • copier tech
                      • 8220
                      I would sugest your issue is due to compatible toner & drums using these cheap substitues often cause issues.
                      • q555
                        • May 2015
                        • 81
                        yes, absolutely right. but we dont have any choice but to use compatibles
                        • copier tech
                          • 8220
                          I feel your pain.
                          Try another brand, some are really awfull.
                          • teckat
                            • 16083
                            ask the Queen ?
