Canon IR2200
  • Preco
    • May 2017
    • 1
    Canon IR2200
    I Need bootrom 26.44N and PS/PCL firmware. Have machine with network card but wont print
  • copier tech
    • 7979
    Re: Canon IR2200
    The N boot rom is a physical chip you need to fit in order to enable the print function.
    Simply fitting a LAN card is not enough & you wont be able to install the N firmware without this chip.
    • teckat
      • 16092
      Re: Canon IR2200
      Copier Boot ROM for the iR2200/2800/3300 is part #FG3-1743-040.
      Network Boot ROMs are controlled parts and cannot be ordered.
      The Network Boot RomDIMM is not stocked as a service part.
      To upgrade a stand alone machine into a network machine, a Multi PDL Kit must be installed.
      The Network Boot DIMM wil be included in the kit.
      imageRUNNER 2200 /2800 /3300 >
      Multi-PDL Printer Kit-C1
      • copier tech
        • 7979
        Re: Canon IR2200
