IR Avance C3520
  • bomberi
    • 107
    IR Avance C3520
    I have canon IR ADVC3520 copier that will make me always please wait on the screen at 99% starting. It's a new machine for me and i have any Ideas but for others canon copiers the problem can be HDD or systeme.Thank you for your help.
  • copier tech
    • 8138
    Re: IR Avance C3520
    Hi,
    Does it ever move from 99% or is it permanently stuck on please wait screen?
    • bomberi
      • 107
      Re: IR Avance C3520
      Thanks, it is permanently on please wait screen.
      • Cipher
        It's not easy being green
        • May 2006
        • 1309
        Re: IR Avance C3520
        I'd start with a boot up diagnostic / box check.
        Code:
        Turn on the main power switch while pressing the numeric keys ‘2’ and ‘4’ simultaneously.
        That will give you some PCB chip checks and a HDD read/write test. (should roughly be around 100Mb/s)
        If that all checks out maybe try a 'overwrite all' update via USB.
        • Cipher
          • May 2006
          • 1309
          Re: IR Avance C3520
          Pic of a C3520 I checked this morning.
          • bomberi
            • 107
            Re: IR Avance C3520
            Thank you for your helps, I will do this check to see the result.
            • roho
              • Mar 2009
              • 844
              Re: IR Avance C3520
              See if you can enter service mode, usually you can when the line gets that far, check for error codes in history or if one is still active. If you see a stuck error it may help tip you to what you should do next. You could also try a MMI clear in service mode as well and reboot.
              • bomberi
                • 107
                Re: IR Avance C3520
                I do the diagnostic and the result is OK so I think I can change the HDD and download the firware. So I want the kind of hdd I can use and who can help me with the firmware. Thank you for your helps.
                • Cipher
                  • May 2006
                  • 1309
                  Re: IR Avance C3520
                  IF the result is OK I don't see the point of replacing the HDD.
                  I'd start with a overwrite all reload of the software, and go from there.
                  • bomberi
                    • 107
                    Re: IR Avance C3520
                    [QUOTE=Cipher;599565]IF the result is OK I don't see the point of replacing the HDD.
                    I'd start with a overwrite all reload of the software, and go from there.[/QUOTE
                    Thanks, so you said that the hdd is good but i can download the firmware. I have no it.
                    • Cipher
                      • May 2006
                      • 1309
                      Re: IR Avance C3520
                      Is there no Canon partner in Niger that you can contact?
                      Where did you buy the machine from?
                      PM sent.
