Background on copies
  • NM0174
    • Mar 2013
    • 38
    [Misc] Background on copies
    The copy comes out with a background as in the picture. Drum, dev tank and tonner are new. Please help
  • rudysemira
    • Oct 2016
    • 108
    Re: Background on copies
    Is this happen when you changing new toner? if yes, you are using not genuine toner for the first time and base on my experience i used to clean the developer and remove the remaining toner and try it again to use your new toner without mixing old toner from the developer....good luck
    • NM0174
      • Mar 2013
      • 38
      Thank you. Even if you take a drum and dev tank from a perfectly working machine. You still get the same copy with a background
      • roho
        • Mar 2009
        • 844
        No blanking on the prints, usually wrong charged toner, so if you can absolutely rule that out, I would be looking for a electrical problem, as there is no lead edge blanking.
        • JPiek
          • Oct 2014
          • 435
          How does the fuser look ? if you have a spare machine, maybe you can swap and try ?
          Johan
          • Canuck
            Tech Specialist
            • 1713
            MODEL????
              • 23010
              Originally posted by Canuck
              MODEL????
              I'm glad I wasn't the only one to notice this. It's really hard to offer specific device when when we don't know what model.
              In general yes, wrong toner can produce this exact effect. =^..^=
              • NM0174
                • Mar 2013
                • 38
                Replying message from 2018[emoji85][emoji85]
                My bad, phone got damaged during that period and I lost comms for 3 months
                This problem was on an IR2520. I eventually discovered that it was the drum unit that had a problem. Bias voltage must have been "leaking". As soon as I put the drum, blade and charge roller on a new unit, copies became 100%.
                Sent from my SM-G965U using Tapatalk
                • Cligerson
                  Double-check the toner. I think you did not put it back right. Sometimes the paint isn't of the best quality, and if it's liquid, it spills everywhere if it's powder, it goes on the toner and leaves this kind of spot and stripes. Try to print an image, anything from your stock illustrations; this might fix the printer. In general, it's recommended to have the printer filled and cleaned by a person who knows how to do it. Don't do it by yourself if you don't know-how. Trying to save up some money leads to this!
