canon ir 2520..dirty copy
  • montana
    • Aug 2008
    • 392
    hi.i have an issue with canon ir2520.it is giving dirty copy and print.ireplaced the toner.after i vacum the old one.but the same result.any ideas?thanks
  • roho
    • Mar 2009
    • 844
    Re: canon ir 2520..dirty copy
    How is the drum, fuser?
    • copier tech
      • 8222
      Did you vac out the toner because you are using non OEM toner?
      • ablepe
        • 40
        Add some pics,but probably is drum
        Sent from my Lenovo K33a48 using Tapatalk
        • guitar9199
          • Sep 2016
          • 1100
          +1 on the drum. Those fail pretty spectacularly..... Usually right after they reach rated life.
          Pull the old drum, install new one, you're good to go.
          • montana
            • Aug 2008
            • 392
            the drum looks good.but i did not chek the fuser
            • montana
              • Aug 2008
              • 392
              yes.it is correct
              • Canuck
                Tech Specialist
                • 1713
                How many copies on machine? Those drums last a long time.. I've seen them run over 200k.
                • copier tech
                  • 8222
