canon ir adv6055 6065 6075
  • crisjala
    • Feb 2018
    • 3
    [Misc] canon ir adv6055 6065 6075
    How to downgrade canon ir advance 6075 to 6065? I cannot find a replacement main controller pcb 1 for 6075 but i have 6065 is it possible to downgrade the speed what particular parts should i replace if it is possible?
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: canon ir adv6055 6065 6075
    Officially the answer is most definitely no.
    Even unofficially it's not recommended or practical to attempt a swap out, the margin for error and running into other problems is high.
    • teckat
      • 16083
      Hytec Circuit Board, Print Controller, Stapler, Power Supply, Fuser Repair Catalog
      send for repair
      FM4-5301-000==iRADV6065
      ------------010
      do a GOOGLE search--------many available --used >sale --repair/*CORE EXCHANGE
      • copier tech
        • 8192
        It can be done, you'll just need to swap ALL boards & HDD in the soft counter circuit at the same time.
