Jam 011A in POD Deck Lite C1 ( iPC 650 )
  • Ingranaggio_rotto
    • Oct 2010
    • 274
    Good evening everyone !
    I have several POD Deck Lite C1 jammings with J011A code with the most varied types of media (plain, coated, heavy, etc ).
    Despite POD regulations, customization of media supports, the problem remains....
    Suggestions ?
  • teckat
    • 16083
    Re: Jam 011A in POD Deck Lite C1 ( iPC 650 )
    Suggestions ?
    jam only from pod decks
    POD Deck Lite C1
    CANON POD DECK LITE-C1 SERVICE MANUAL Pdf Download.
    • onlyinnewfoundland
      • Apr 2013
      • 235
      Suggestions ?
      Hey - I've got one of these in my area.
      When I installed POD there is a kit to change some of the brackets that sensors sit on. I think either Canon forgot to put it in the box, or I accidentally threw it away (most likely) as it was probably attached to some of the packing material.
      I had a hell of a time feeding any thicker media through the pod. Plain papers worked okay, but anything over 220 GSM forget it. Thin coated would sometimes work.
      It is just one or two metal brackets that change the angle of the deck sensors to allow for thicker media.
      Most people in my area with these machines have decided to buy the multi-drawer paper deck instead.
      I can't seem to find the tech pub at the moment, but I am willing to bet it is under the installation section in the service manual for the POD by now.
      Good luck
      • teckat
        • 16083
        Good luck
        Installation & parts needed in manual link above --- see start page 100
        • Ingranaggio_rotto
          • Oct 2010
          • 274
          Thanks for your help...
          Thanks Teckat for the manual that I have anyway....
          The POD is installed correctly and well aligned with the machine.
          Despite the various Canon Service Bullettins with setup and various precautions these fastidiode jams persist.
          I ask: are the rollers the cause of everything?
          Would you like to solve by installing different types?
          Has anyone solved differently?
          • teckat
            • 16083
            how far does paper feed out if/u get feed at all
            • Ingranaggio_rotto
              • Oct 2010
              • 274
              Sometimes the head of the sheet does not even reach the pair of rollers that help the paper to exit the POD to enter the machine .....
              • teckat
                • 16083
                Paper height is then the issue, sensor thinks paper is at position for pickup.
                That is the delay jam u have.
