Maybe somebody knows which drums are in this new device? Thanks!
Canon IR C3025i
Re: Canon IR C3025i
Canon 8528B003 (C-EXV 49) Drum unit, 75K pagesimageRUNNER C3025i / C3025[/COLOR] Canon C-EXV 49 Drum Unit
imageRUNNER C3025i / C3025[/COLOR] Canon C-EXV 54 Toner Black
Canon C-EXV 54 Toner Cyan
Canon C-EXV 54 Toner Magenta
Canon C-EXV 54 Toner YellowCanon C-EXV 49 Drum Unit **Knowledge is time consuming, exhausting and costly for a trained Tech.**
Re: Canon IR C3025i
Thanks Tec!
Probably 4x C-EXV 49If it ain't broke, don't fix it
A picture is worth a thousand wordsComment
Re: Canon IR C3025i
yes !!!!!!!!!
Procedure for Replacing the Drum Unit
When you perform the following procedure, the screen also displays the instructions for drum unit replacement, which will be helpful for you to be sure of the procedure.
Select <Status Monitor>
<Error Information/Notification>
<Replace Drum Unit>.
1
Open the front cover of the main unit.
2
Open the cover of the drum unit.
3
Pull out the drum unit.
Do not tilt the drum unit. Doing so may cause the toner in the drum to spill.
4
Remove the new drum unit from its box.
5
Install the new drum unit.
6
Remove the protective cover.
First push in the slider on the right side of the orange-colored protective cover toward the back of the main unit until it cannot go any further, and then pull out the protective cover.
7
Close the cover of the drum unit.
8
Close the front cover of the main unit.
After the replacement is complete, put the used drum unit in the bag that contained the new drum unit, and store it until the local authorized Canon dealer comes to collect it.
imageRUNNER C3025i / C3025**Knowledge is time consuming, exhausting and costly for a trained Tech.**
