Canon IR C3025i
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Canon IR C3025i
    Maybe somebody knows which drums are in this new device? Thanks!
    • 16083
    Re: Canon IR C3025i
    Canon 8528B003 (C-EXV 49) Drum unit, 75K pages
    imageRUNNER C3025i / C3025[/COLOR]
    Canon C-EXV 49 Drum Unit
    imageRUNNER C3025i / C3025[/COLOR] Canon C-EXV 54 Toner Black
    Canon C-EXV 54 Toner Cyan
    Canon C-EXV 54 Toner Magenta
    Canon C-EXV 54 Toner Yellow
    • zoraldinho
      • Mar 2008
      • 5015
      Re: Canon IR C3025i
      Thanks Tec!
      Probably 4x C-EXV 49
        • 16083
        Re: Canon IR C3025i
        Thanks Tec!
        yes !!!!!!!!!
        Procedure for Replacing the Drum Unit
        When you perform the following procedure, the screen also displays the instructions for drum unit replacement, which will be helpful for you to be sure of the procedure.
        Select <Status Monitor> <Error Information/Notification> <Replace Drum Unit>.
        1
        Open the front cover of the main unit.
        2
        Open the cover of the drum unit.
        3
        Pull out the drum unit.
        Do not tilt the drum unit. Doing so may cause the toner in the drum to spill.
        4
        Remove the new drum unit from its box.
        5
        Install the new drum unit.
        6
        Remove the protective cover.
        First push in the slider on the right side of the orange-colored protective cover toward the back of the main unit until it cannot go any further, and then pull out the protective cover.
        7
        Close the cover of the drum unit.
        8
        Close the front cover of the main unit.
        After the replacement is complete, put the used drum unit in the bag that contained the new drum unit, and store it until the local authorized Canon dealer comes to collect it.
