canon M40
  • walidcharifi
    • Feb 2011
    • 379
    canon M40
    hi
    i have colortrac m40 I am looking for their driver .
    but I find nothing.
    I TEST WITH DRIVER SC SCANNER V2.0.0.4
    **NO SCANER DETECTE**
    I DOWNLOAD CANON SmartWorks MFP
    SCANER DETECTE - NO PRINTER-
    I want to use it alone because I do not have the printer
    HELP ME PLZ
  • teckat
    • 16083
    Re: canon M40
    Originally posted by walidcharifi
    hi
    but I find nothing.
    HELP ME PLZ
    don't think possible
    what is your setup ??
    Canon imagePROGRAF M40 Smartworks MFP Classroom
    • walidcharifi
      • Feb 2011
      • 379
      Re: canon M40
      THANKS.
      I INSTALL THIS SOFTWARE .... I dont have PRINTER
      I want to use only the scanner
      • teckat
        • 16083
        Re: canon M40
        THANKS.
        Where did u get this scanner from ?
        Usless without an IPF attached.
        No printer, so what do u need it for ?
        • teckat
          • 16083
          Re: canon M40
          Does your PC or MAC see this M40 Scanner
          • walidcharifi
            • Feb 2011
            • 379
            No ipf attached .
            Scanner detected in software .
            Message appear . PRINTER NO DETECTED .
            • teckat
              • 16083
              Re: canon M40
              No ipf attached .
              did u connect to PC ??
                • 23007
                Re: canon M40
                Well ... the printer is not detected because there is no printer. Did you expect some other result? =^..^=
                • teckat
                  • 16083
                  Re: canon M40
                  Right On the Money
                  • walidcharifi
                    • Feb 2011
                    • 379
                    Re: canon M40
                    I wanted to ask ... Can it be used without a printer?
                    I want to use the scanner only because I do not have the printe
                    • walidcharifi
                      • Feb 2011
                      • 379
                      Re: canon M40
                      Right On the Money
                      [ATTACH=CONFIG]39636[/ATTACH]
                      I want to use the scanner only because I do not have the printe.
                      • teckat
                        • 16083
                        Re: canon M40
                        and where did u want these scans to go if no printer ?
                        if u can't directly connect a scanner to a PC or MAC or a Wi Fi > u are out of luck---------sell it on eBay
                        • walidcharifi
                          • Feb 2011
                          • 379
                          Re: canon M40
                          so ... i can not do a scan to pc
                          • teckat
                            • 16083
                            Re: canon M40
                            if u can connect to a PC> and Windows does not see it > u are wasting time
