Canon IC D1550 Error Code E000
  • AISI
    • 49
    Working on a Canon D1550 with the system error E000. My question is can you reset a Fuser error code on that model and if so how? I thought i got into service mode by pressing Menu , 28, Menu? and went to clear error but it did not work. Fuser was replaced about 3 months ago and i would think it would not be coding again?Am i doing something wrong?
    Any help would be appreciated. Thanks
  • Brian8506
    • 1665
    Re: Canon IC D1550 Error Code E000
    That may be similar to some newer that reset differently. It may be clear/engine if it has that option
    Sent from my iPad using Tapatalk
    • teckat
      • 16083
      Service Mode ?
      Home Button ->then press #2 Numeric key -> then press #8 Numeric key -> then press Home Button > should get you into Service mode.
      Temperature of the Fixing Assembly did not reach a certain temperature
      within the specified period of time.
      Don't believe there is a E000 clear on this model-
      > If an error occurs, turn OFF and then ON the power first to check whether the same error occurs. (In the case of controller-related
      errors, the machine may recover by turning OFF and then ON the power.)
      1. Check the connector connection between the Fixing Assembly and the Engine Controller PCB.
      2. Replace the Fixing Assembly.
      3. Replace the Engine Controller PCB.
