ligth image ir-adv8585
  • dracon
    • Apr 2016
    • 16
    [CQ] ligth image ir-adv8585
    Hello everyone.
    I have a problem with an Ira-adv8585 machine.
    The problem is only as a printer, not as a copier.
    The problem is that sometimes it prints little intensity (not always and only with some files, these files have been tested in another machine equal and go well)
    As a copier, she has never had a problem.
    It is the same to print in postcription, VFR or direct printing on a pendrive.
    We have increased the level of intensity as a printer at the user level but sometimes the quality is not good.
    As it does not always happen, we thought there was a temperature problem in the client since in winter there are only between 12 and 16 degrees but now the temperature is normal and still bad.
    In a knowledge base I have seen a similar problem in ir-adv8085 and it is to restore factory data. But my question is if after the reset load the machine backup.
    Thanks for everything.
    Greetings.
  • teckat
    • 16083
    Re: ligth image ir-adv8585
    What is Set up for
    Printing
    imagePass Y1 ?
    Print Kits ?
    Drivers Used ?
    Applications Using ?
    • dracon
      • Apr 2016
      • 16
      On Friday the problem has been solved.
      I have made a factory reset and with a p-print I have entered the parameters.
      Now with any pdf in usb, PS or VFR the quality is correct.
      Thank you very much.
      regards
      • COPIERTEC ASSOCIATES
        • Aug 2011
        • 279
        regards
        Good innovation!
