Canon IR3180ci Blank Pages?
  • steve1973
    • Sep 2013
    • 43
    Any help would be welcome,Canon IR3180 producing blank pages only?,removed delivery tray to check image formation, and theres no image forming on the ITB,also dev units don't appear to be rotating?
  • teckat
    • 16083
    Re: Canon IR3180ci Blank Pages?
    No error codes ?
    • steve1973
      • Sep 2013
      • 43
      Only recent error code was E0732 that was related to paper pickup rollers on cassette one that were worn down and not picking up, new ones fitted and seemed to sort it, but nothing related to this blank page problem.The machine has recently had both cyan and magenta dev units replaced and weirdly since then has made an audible beep? when printing, but has printed ok.This was a couple of weeks ago but now is printing only blank pages,there was no audible beep on the old dev units?.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        No image on itb? No errors?
        Laser shutter?
        • Canuck
          Tech Specialist
          • 1713
          Make sure itb cleaner blade is not stuck against itb. Does itb turn?
          • steve1973
            • Sep 2013
            • 43
            Itb is turning fine, have inspected it on start up and noticed that patch images are forming for all colours on the belt ok during startup, but nothing when printing/copying.
            • teckat
              • 16083
              U have patch images = means all is turning
              so now
              Check Secondary Transfer Roller -applies image from ITB to Paper
              • zoraldinho
                • Mar 2008
                • 5015
                so now
                I agree.Transfer issue.
                • steve1973
                  • Sep 2013
                  • 43
                  Still only have patches formed at startup, have tried printing internal test pages but nothing forming on itb,have still got an audible tone,1 beep for each colour as rotary turns,guess theres no way to print test patches on startup?
                  • steve1973
                    • Sep 2013
                    • 43
                    Is there a way i can check to see if an image is forming on the drum?
                    • teckat
                      • 16083
                      No,
                      The previous latent image on the drum is removed and the drum is conditioned for the new latent image. ... As the drum turns, an invisible latent image is created on the drum.
                      Simple troubleshooting , if u get patches formed on ITB, and they don't transfer to Paper, U need to look at your secondary transfer roller operation.
                      Forming of the Patches or images from Printing or Copying on ITB prevents Error Codes.
                      If nothing was being seen by patch sensor u would get development error codes.
                      • copier tech
                        • 8176
                        There is a copier charge contact that needs to make good contact with the secondary transfer roller, check both these contacts.
                        Replace the ITB if in doubt, especially if it has done over 300k.
                        • copier tech
                          • 8176
                          Error code E0732 has nothing to do with paper feed.
                          Are you a tech?
                          • steve1973
                            • Sep 2013
                            • 43
                            Thanks for responses, no i'm not a tech so forgive me if i get any of this wrong, would a second transfer issue prevent prints/copies (inc internal prints) from being formed on itb as i get nothing this way?,have also tried from pc but nothing,i can understand a transfer issue if images are on itb.
                            • copier tech
                              • 8176
                              The fact that you can see the patches formed on the ITB but not when you print? Try a PG10 test print run stop the machine mid run (open the RHD) are you SURE there is no image on the belt?
