Imagepress c 6010 e0260-2017-05
  • mc921
    • Oct 2015
    • 23
    I had to remove the dc controller assembly to service the waste toner buffer unit. Replaced the buffer with No issue. Now the printer immediately signal error code e0260-2017-05. Power supply issue...
    I have re seated all connectors multiple time with No luck. Anybody have any thoughts?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Imagepress c 6010 e0260-2017-05
    Did you check for Hopper driver PCB (Y); 13V ?
    • mc921
      • Oct 2015
      • 23
      Ok...i seated all the connections to the yellow hopper...and the code changed. Now the error code is e260-101d-5. 24v issue.
      • zoraldinho
        • Mar 2008
        • 5015
        Still Hopper driver PCB (Y)
        • mc921
          • Oct 2015
          • 23
          Cool..ill look into this again. I must gave old manual...nobe of these codes are referenced. Thanks...ill let you know the results.
          • zoraldinho
            • Mar 2008
            • 5015
            Inspect jack no:J1620Y/J1611Y on drum driver pcb and hooper driver pcb jack no:J1420Y/J1410Y
            Good luck
            • mc921
              • Oct 2015
              • 23
              Ok...i checked the hopper driver pcb...connections secure...even swapped out the yellow driver with magenta...same code. Checked the yellow drum driver pcb...also swapped with magenta. Same code.
              I'm perplexed because the other than the buffer unit which I Replaced, the machine was working fine. I keep going back to dc controller and an ill fitting connection...but the connections look good. Any other thoughts?
              Thanks again for your assistance.
              • zoraldinho
                • Mar 2008
                • 5015
                • zoraldinho
                  • Mar 2008
                  • 5015
                  http://www.copytechnet.com/forums/at...1000-error-pdf
                  • mc921
                    • Oct 2015
                    • 23
                    I saw teckats earlier post on the led arrangement for PS diagnostics. It appears all the let's are activated. Still looks like a connector....
                    • zoraldinho
                      • Mar 2008
                      • 5015
                      Definitely a connector because the machine worked before you ....
