Imagepress c 6010 e0260-2017-05
  • zoraldinho
    replied
    Re: Imagepress c 6010 e0260-2017-05
    Definitely a connector because the machine worked before you ....
  • mc921
    replied
    I saw teckats earlier post on the led arrangement for PS diagnostics. It appears all the let's are activated. Still looks like a connector....
  • zoraldinho
    replied
    http://www.copytechnet.com/forums/at...1000-error-pdf
  • zoraldinho
    replied
  • mc921
    replied
    Ok...i checked the hopper driver pcb...connections secure...even swapped out the yellow driver with magenta...same code. Checked the yellow drum driver pcb...also swapped with magenta. Same code.
    I'm perplexed because the other than the buffer unit which I Replaced, the machine was working fine. I keep going back to dc controller and an ill fitting connection...but the connections look good. Any other thoughts?
    Thanks again for your assistance.
  • zoraldinho
    replied
    Inspect jack no:J1620Y/J1611Y on drum driver pcb and hooper driver pcb jack no:J1420Y/J1410Y
    Good luck
  • mc921
    replied
    Cool..ill look into this again. I must gave old manual...nobe of these codes are referenced. Thanks...ill let you know the results.
  • zoraldinho
    replied
    Still Hopper driver PCB (Y)
  • mc921
    replied
    Ok...i seated all the connections to the yellow hopper...and the code changed. Now the error code is e260-101d-5. 24v issue.
  • zoraldinho
    replied
    Did you check for Hopper driver PCB (Y); 13V ?
  • mc921
    started a topic Imagepress c 6010 e0260-2017-05
    I had to remove the dc controller assembly to service the waste toner buffer unit. Replaced the buffer with No issue. Now the printer immediately signal error code e0260-2017-05. Power supply issue...
    I have re seated all connectors multiple time with No luck. Anybody have any thoughts?
