IR C5030 with error E000025-0110
  • compucal
    • Jul 2011
    • 17
    Good Morning,
    We have to go on a service call for a Canon IR c5030.
    As per user, error E000025-0110.
    Previously had a yellow toner leakage.
    Another company tech cleaned it out a week ago, started to work, and error showed up a day ago.
    Any suggestion? What is the error ?
    Regards & Thanks,
    Ron
  • JPiek
    • Oct 2014
    • 435
    Re: IR C5030 with error E000025-0110
    E025 0110 05 Timeout error in detection of Y Toner Bottle Seal/Release
    Sensor
    Failure in detection about the changes of ON => OFF => ON
    with the sensor when the cap of the Y Toner Container was
    sealed/released.
    Remedy :
    1. Use the attached tool to manually rotate the Main Drive
    Unit to check the operation.
    2. If the Main Drive Unit side failed to rotate, check the drive
    (to see damage of the gear, etc.)
    If it’s results in NG, replace the Main Drive Unit.
    3. If the Main Drive Unit side failed to rotate while the Drive
    rotates, turn the Set-on Hopper Unit to check the rotating
    operation. If it’s results in NG, replace the Set-on Hopper
    Unit.
    4. If both the Main Drive Unit and the Set-on Hooper Unit
    rotates together once the Main Drive Unit is manually rotated
    while sealing/releasing of the container works properly,
    check the sensor harness (to see if the harness is caught,
    disconnected or physically removed).
    5. Replace the sensor which has been checked in step 4.
    6.(If the above measures do not solve the problem,) Replace
    the Drum Driver PCB (UN4).
    NOTE: When checking the operation after performing
    the remedy, go through the following to clear the error:
    COPIER>FUNCTION>CLEAR>ERR; then, turn OFF and
    then ON the power. After performing the remedy, perform the
    toner replacement operation (from toner removal to reset/
    recovery) from the Control Panel at least once, and check
    that the replacement operation can be performed normally
    Considering someone has been 'waving around' with a tonervac, brush or cloth inside the machine, i'd check #4 first...
    Johan
    • JPiek
      • Oct 2014
      • 435
      nr9 afaik
      Johan
