Canon IRA C2225 Blank Streak on Copies/Prints
  • doug
    • Dec 2011
    • 198
    Hi Guys,
    Customer has blank streaks on a Canon IRA C2225 no matter if it is from printing from the computer OR making a manual copy from the doc. feeder.
    I posted this problem earlier, but I would like to know if anyone has any new ideas...the last machine that had this problem I had to replace because I couldn't fi it. (now same problem on this one!)
    Annnd! This machine only has 6,333 prints/copies total!
    Thanking you in advance for any help.
    Doug
  • Brian8506
    • 1665
    Re: Canon IRA C2225 Blank Streak on Copies/Prints
    Did you clean the laser glass. There is a procedure for that, not sure of the specifics.
    • Herrmann
      • Jan 2006
      • 792
      Service Mode: COPIER > FUNCTION > MISC-P > SHT-OPEN
      Pull out the Drum Unit
      Remove the Dustproof Glass cleaning tool from the Front Cover
      Insert the Dustproof Glass cleaning tool into the groove, and clean the Dustproof Glass
      Hope that helps
      If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
      • guitar9199
        • Sep 2016
        • 1100
        Hope that helps
        I've done this procedure, but I've found it's MUCH easier to just remove the left cover, take the laser unit out of the machine, and clean it that way. Plus it'll give you a chance to see if one of the developer units is dumping toner on top of the laser.
        Not a fan of how Canon designed the laser cleaning procedure on this model. It's much easier to do on the Adv 5000/5200 series machines.
        • JPiek
          • Oct 2014
          • 435
          Advantage of this way of cleaning is you can clean the whole laserunit, not just the glass. It seems the whole unit is covered in toner from time to time...
          Sometimes the mylars inside are dirty to...
          Johan
          • copier tech
            • 8188
            If cleaning the laser glass does not help you only have one option replace the black drum.
            Awful machine.
