HDD wipe
  • JSC
    Gimp
    • Dec 2006
    • 618
    HDD wipe
    Evening,
    We are Kyocera & Konica Minolta dealers and have won an account where we need to wipe the memory and hhd on 3 old(ish) Canons. The models concerned are:
    5240i
    5235
    5030
    We know nothing about Canons. If someone could PM me the instructions i'd appreciate it.
    Thanks...
    The gene pool could use a little chlorine.
  • lilleputte
    • Jan 2013
    • 153
    • teckat
      • 16083
      Re: HDD wipe
      Initializing All Data/Settings
      If this mode is performed, the following data stored in the machine are completely erased. It is not normally necessary to use this mode, but it is useful to erase personal or confidential information when returning or disposing of the machine.
      Data stored in mail boxes/Advanced Box
      Data stored in Fax/I-Fax Inbox (Confidential Fax Inbox/Memory RX Inbox)
      Address data stored in the Address Book
      Scan settings registered for the Sending function
      [Favorite Settings] registered for the Copy, Store/Access Files, and Send functions
      MEAP applications and license files
      Data saved from MEAP applications
      The password for the SMS (Service Management Service) login service of MEAP
      (If you changed the password, it returns to the default password.)
      User authentication information registered in the Local Device Authentication system of SSO-H (Single Sign-On H)
      Unsent documents (reserved documents and documents set with the Delayed Send mode)
      Job history
      Settings/Registration settings
      Forms registered for the Superimpose Image mode
      Registered forwarding settings
      Key Pair and Server Certificate registered in [Certificate Settings] in [Device Management] in [Management Settings] (Settings/Registration)
      • copier tech
        • 8172
        Re: HDD wipe
        If you want to be sure you have wipped ALL data from the HDD, remove the drive from the copier, fit it in a HDD caddy then format the drive in Windows.
        • JPiek
          • Oct 2014
          • 435
          Re: HDD wipe
          Not 100% true, you can undelete/unwipe any disk if you do a plain format... create a Wipe CD with G-Disk (How to perform a hard disk wipe using the Ghost utility called GDisk)
          and you'll be 90% sure. For 100% sure use a certified wipetool (costs $) like 'Youwipe'...
          Wipetools erase data by overwriting it several times with 1's and 0's
          Johan
