Hard Drive replacement
  • copiman
    • Sep 2011
    • 861
    First of all I am new to the Canon product. I have worked on other manufactures and found that any hard drive would work despite the fact that the manufacture said you must use theirs. Having said that, can any hdd be used on the Canons? I have read a few posts but just got confused. Probably because I'm new to the product.
  • teckat
    • 16083
    Re: Hard Drive replacement
    If the Canon SST HDFormat program does not recognize the HDD u will not be able to format and load in the firmware.
    The newer HDFormat files are encrypted, so u are not able to modify the HD Descriptor file (which would recognize the HDD being used.
    • teckat
      • 16083
      HDD Not Found Message.
      When attempting to format a hard drive in a Canon
      ImageRUNNER you receive a message from the
      SST advising that theHDD cannot be found in the drives file.
      (Service Support Tool) (Hard Disk Drive)
      HDD Descriptor File
      This is the file which contains the descriptor information for each HDD registered fot he Canon model. The naming of these files is important to understand as you will need to track these files down when you want to format non-standard HDD's.
      iRModel: This will be the model designation for the unit. iR2200 for example. iRXXXX files are encrypted.
      XX: A double X appears in this position for all such files.
      xx: This is the language designator for the firmware files. Since the HDD file is universal this is always xx.
      ####: This is a version number which will correspond to the firmware version number you see in the SST.
      HDFormat: The type of file which is always HDFormat for the HDD Desriptor file. .ift: TheWindows file type. This is used for all Canon Firmware files.
      iRModel-XXxx####-HDFormat.ift
      Overview
      The SST provides the ability to properly format new hard drives or reformat corrupted hard drives in Canon ImageRUNNERs.
      Sometimes you will try to format a drive and will receive a message advising you that the unit has an invalid disk installed. This message indicates that theImageRUNNERhas a non-standard HDDinstalled and the SSTdoes not recognize it.
      When you load the firmware for a Canon device into the SST part of the information provided is a list of valid hard drive designations for the model. This list of HDD's not only specifies the name of each valid drive type but also the hardware specifications such as number of read/write heads, platters, surfaces, segment sizes and other technical data describing the features and capacity of the
      HDD to the SST. Canon updates these lists when they use different forms of drives in the different models of copiers and when you install a more recent version of the firmware for a model into your SSTyou are also updating this list of HDD's.
      (Read: Non-Canon)
      EncryptedHDDFiles
      Originally these HDD Dewcriptor Files were regular text files which could be editted to add new HDD formats when necessary. More recently Canon has started encrypting the files to prevent them being editted. As such, newer model Canon ImageRUNNER's will require that authentic Canon HDD's be installed should they require replacement. Generic drives may not be on
      the list of supported drives for the SSTand Canon will not release a list of supported drives.
      Examples of Edittable vs. Encrypted files would be:
      Edittable: iR2200/2800/3300 iRC3100 iRC5800/6800
      Encrypted: iR2270/2870/3370 iRC3380 iRC4580/5180
      Modifying theHDDDescriptor.
      If the HDFormat file for the model you wish to format is
      Edittable you can create a new entry in the file to allow it to support your hard drive.
      You will need to determine the model of the HDD you
      are trying to format to begin. The model will have been
      displayed in the error message fromt he SST. it is also printed on the outside of most HDD's.
      Steps to Modify the File
      1. Find the Correct HDD Descriptor File
      2. Disable Read-Only protection
      3. Locate Similar HDD Descriptor
      4. Create Copy of Descriptor and Modify
      5. Increment Supported HDD Counter
      6. Save Modified File
      7. Re-Enable Read-Only Protection
      Search the hard drive of your PC for *.ift files. You will be provided with a list of these files. Find the apropriate HDFormat file in the list. The list will be similar to the example below. The example provided is for an iR2200 and is version 13.
      2. Disable Read-only Protection
      The HDFormat files can be set to READ-ONLY which would prevent you from saving your
      revised file at the end of this procedure. Right-click on the file you will be modifying in the list and click on
      the word Properties in the menu that appears.
      If the Read-Only box is checked, uncheck it and click theOKbutton. If it isn't checked you can just
      click on theOKbutton without making any changes.
      3. Locate SimilarHDDDescriptor
      Open the file in Notepad and scroll down to the HDD Dscriptors.You need to locate an entry in the list of valid HDD's that is similar to the one you need to configure to support your drive. The more similar the better.Go through the entire list and locate the best match possible.
      Myexample drive is to be a Toshiba MK8025GAS drive. I have located an entry for the ToshibaMK2023GASdrive which is very similar.
      4. Create Copy of Descriptorand Modify
      Highlight the block of text related to the HDD Dscriptor you have chosen and copy it using Ctrl-C. Click the mouse on the blank line below the entry and press Ctl-V to create a new copy. Make certain there is a single blank line before and after the new entry.
      Edit the new entry to match your drive. in this case i changed 2023 to 8025 creating an entry in the table formyMK8025GASdrive.
      5. Increment SupportedHDDCounter
      Scroll down to the bottom of the list of supported
      HDD's (Note: Not the bottom of the file.) and find the entry
      for the number of drives supported. As you have added a
      new drive you must increment this file by 1. If it was 52,
      you change it to 53.
      6. Save the Modified File
      Click on File and Save to save your changes.
      7. Enable Read-only Protection
      If you had unchecked the Read-Only box in the
      HDFormat file's properties in step 2, you will now open the
      file's properties again and check the Read-only box to
      protect the file.
      Now that the new entry is in the HDFormat file you should be able to format the drive on your ImageRUNNER using the SST.
      • copiman
        • Sep 2011
        • 861
        Thanks for the response. I have never used the SST before. We just use USB. May try SST in the shop just to get familiar with it. Guess Canon has a monopoly on the HDDs. I was hoping we could use different hard drives like I did on Kyocera. Saved a lot. Oh well, I guess we will just have to buy HDDs from Canon. Thanks again for your helping me.
        • copier tech
          • 8217
          What model are you referring too? all later IRADV Canon you can fit a new HDD (if using correct one) then format the drive & install the firmware using a prepreparred USB stick via SST.
          • copiman
            • Sep 2011
            • 861
            Thanks copier tech. I was talking in general. I was told that you can only use Canon hard drives. I have worked on other manufactures machine and always used any hard drive, not the manufacturers. I am new to canons but have been in copiers since 1982.
            • copier tech
              • 8217
              Best way to be sure is order an identical HDD that you currently have fitted in the machine.
