Canon ir ADVANCE C2020 service mode
  • Alex1
    • Oct 2012
    • 287
    I have a Canon IR ADVANCE C2020 i cant access service mode. The access is usually settings registration 2 and 8 then settings registration again. And nothing happens at all. Ive done this a number of times on other machines and it accesses fine. But i cant on this any suggestions.
  • copier tech
    • 8220
    Re: Canon ir ADVANCE C2020 service mode
    Remember its the additional functions key 28 not the standard *
    Check that you don't have a sticking button,
    reboot the machine and hold down 2+8 if you get download mode buttons are OK, if you get a reboot you got a sticky key in the control panel.
    Alternative service mode entry is 4+9 try this.
    • JPiek
      • Oct 2014
      • 435
      Had this happeing a couple of times... It sometimes helps to press 2 and 8 shortly (VERRY short) after another: press 2 (and hold) then 8 immediately, not 2 and 8 at the same time.
      Johan
      • copier tech
        • 8220
        Yes there is a nack to it this prevents the customer accidently logging in service mode.
        • Alex1
          • Oct 2012
          • 287
          Thank you all for your response. I will give it a go this weekend and let you know the outcome.
