Fax L410 Check toner cartridge problem
  • tamboknon
    • Sep 2015
    • 62
    Hi Sir,
    Good day!
    I have this problem check toner cartridge in Fax L410. I already change new cartridge to test. Checked the main drive alighnment. But still problem occurred. Anybody had encounter this problem. Please help me. Thanks in advance.
  • Blizzoo
    • Aug 2013
    • 611
    Re: Fax L410 Check toner cartridge problem
    Hi, I would check if there is a proper connection between toner cartridge and chip reader while the cartridge is inserted. On the older machines a bent HV contact can cause cartridge detection issues.
    • tamboknon
      • Sep 2015
      • 62
      I will check boss. Thank you
      • tamboknon
        • Sep 2015
        • 62
        Hi boss, it is aligned and doing good contact with the chip. I tried to put tape to the chip if there is changes. Still check toner cartridge. Thanks in advance
