Irc adv 2020i sometimes does not print in colour mode only print black colour....
  • ernesto
    • Oct 2011
    • 430
    HI
    Solution: replace fixing drive assy (FM0-1158-010), the solenoid is sticky
    All the best
    • 23010
    Re: Irc adv 2020i sometimes does not print in colour mode only print black colour....
    Ernesto, do you have a theory why a fuser drive assembly might have anything to do with colour versus monochrome printing? I don't see a connection. What does this sticky solenoid do? =^..^=
    • khattab.al.masry
      • 212
      Originally posted by ernesto
      HI
      All the best
      What is the relation between color mode procssing and fixing assembly?
      Sent from my SM-J700H using Tapatalk
        • 16083
        HI
        All the best
          HI
          All the best
          sorry, I cannot see the relationship to the fuser causing no color print.
          are you sure the PRINT DRIVER isn't set to BLACK ONLY?
          does the machine produce color INTERNAL PRINTS?
          what about color copies?
            • 16083
            HI
            All the best
            Auto Color Mode is enabled on the control panel through Settings / Registration.
            Perform the following to enable Auto Color Mode:
            Settings / Registration > Function Settings > Copy > 2/2 > Select Color Settings For Copy > Use Auto(Color/Black) > 'On'.
            There is a setting to limit the machine from copying in "Full Color" mode. Go to Settings & Registration > Function Settings > Copy > Select Color Settings for Copy > set Use Full Color to "On"
            To default the imageRUNNER advance to black and white when coping from the DADF or the glass, select black and white on the control panel of the 'Copy' screen. Next select Settings / Registration > Function > Copy then 'Change default settings' and press 'Ok'.
            Black and white will now be locked in as the default color for copies.
            Black prints fine but none of the colors are being printed and there are no error codes.
            In this case, it was found that the mylar strips on the color laser shutters were hanging up and blocking the color lasers. After resetting the mylars on the laser shutters the problem was resolved
            • Canuck
              Tech Specialist
              • 1713
              No way....Shutters for laser have their own motor to open them. Solenoid for what was sticky?
              • ernesto
                • Oct 2011
                • 430
                Fig.280 FM0-1158-010 1 FIXING DRIVE ASS'Y SL1 (IRC2220 PC)
                it also runs ITB, error code e074 sometimes was displayed.......
                  • 23010
                  So you think that the color primary transfer roller shift mechanism was not keeping the color transfer rollers pressing against the inside of the belt? There's some logic to that. =^..^=
                  • ernesto
                    • Oct 2011
                    • 430
                    Yes I think that, and the black primary transfer roller inside the belt is always static (there is not moving )
                      • 23010
                      I understand. =^..^=
