Ira4025 fax rings
  • Brian8506
    • 1658
    [Misc] Ira4025 fax rings
    Is there a way to change the number of rings for an incoming fax from 2 to 4?
    Re: Ira4025 fax rings
    not for your model... but I kinda doubt they changed it much:
    Canon Knowledge Base - How to change the number of rings before the MX432 '/' MX439 answers incoming call
    • Canuck
      Tech Specialist
      • 1713
      Yes you can on a ira4025. I'm not near a machine but I know for fact that you can on them..fax...auto rx...can't remember. I've had to change them for fax forwarding on VOIP setups. If you're at the machine you can find it. Hit the green "i"for info too
      • Brian8506
        • 1658
        Found it. Service mode/fax/NCU/auto RX/007 change to required number of rings
