IR5075 Constant melting codes
  • finhocamargo
    • Mar 2015
    • 23
    [Error Code] IR5075 Constant melting codes
    Good night, I need help.
    I'm having problems with melting codes on an IR5075 (E001 and 840), error E001 always happens in the morning several times, the machine works a little and during the day happens too. I think the front ends that connect in the meltdown are old and broken, but I also have doubts that it is the board that controls the merger, how can I know if it is the problem in it?
    Thank you very much in advance.
  • copier tech
    • 8133
    Re: IR5075 Constant melting codes
    Replace the fixing roller, thermistors & update the system software.
