IR 2535 BURL copy
  • KHAN
    • Aug 2006
    • 261
    [CQ] IR 2535 BURL copy
    IMG_20180719_151928.jpgHello friends my canon ir 2535 are used so for 80,000 copies ,i used original toner , but last week i have heater error due to the use of GENERATOR because we have electricity problem. when i clear the heater error i got BURL image/FUZZY copy while using making copies or print from the printer, also i take out its own reports the same issue. Please i need help to solve my problem THANKS TO EVERY ONE.
  • teckat
    • 16092
    Re: IR 2535 BURL copy
    Originally posted by KHAN
    [ATTACH=CONFIG]40181[/ATTACH]Hello friends my canon ir 2535 are used so for 80,000 copies ,i used original toner , but last week i have heater error due to the use of GENERATOR because we have electricity problem. when i clear the heater error i got BURL image/FUZZY copy while using making copies or print from the printer, also i take out its own reports the same issue. Please i need help to solve my problem THANKS TO EVERY ONE.
    if issue is from all locations----glass, prints, df ----u may have a damaged Main Controller from power issues
    remove connections and reseat
    • nicknt82
      • Nov 2011
      • 116
      Very simple to solve this. You must enter the value on label of laser unit into service mode.
      • KHAN
        • Aug 2006
        • 261
        Thank you sir for your kind help, you mean that there will be some kind of value labeled on the LASER unit so I note that value and enter that value in some where in the service mode, Please i am new with this model please guide me step by step where should i enter that value i will appreciate and thankful, please
        • nicknt82
          • Nov 2011
          • 116
          Try this: SM> Print Numeric > 136 and 148
          136 : 890
          148 : 1294
          This is my value, you try to enter this value
          • KHAN
            • Aug 2006
            • 261
            136 : 890
            148 : 1294
            Thank you sir for such a useful information and your valuable time, i will try this and let you inform .THANKS
            • nicknt82
              • Nov 2011
              • 116
              If still can't solve. Try to input the default value on label stick on behind cover.
              • KHAN
                • Aug 2006
                • 261
                Thanks my friend i re input all the Numeric data and solve my problem , i think when i clear the heater unit ERROR code we did an ENGINE, ERRCLR but also accidentally did the BKRAMCLR too. finally i solved the problem .thanks a lot for your kind help GOD BLESS YOU ALL have a good day.
