Canon ir adv 8105 dadf tray does not lift
  • amitlama_78
    • Oct 2009
    • 62
    Hi
    Today my dadf stopped working and the tray does not lift... First I got a error 407-0001. Checked the motor and it's ok. If I manually lift the motor my turning the gear the tray lifts and when I turn on the machine the tray goes down but does not lift. Even the paper sensor does not turn on. Little help needed....
    Amit lama
  • dan7777
    • Dec 2012
    • 680
    Re: Canon ir adv 8105 dadf tray does not lift
    Originally posted by amitlama_78
    Hi
    Amit lama
    Check the sensor in the tray. Should get a green light when you push down on that sensor. Just had one on a C7065 where tray would not lift, intermittently (more not than lift). Motor turned, may be a one way gear in the gear train. We had another adf so I just swapped it. Wire inside wire harness known to break. Have had people push the flag out of place for the paper present sensor. The e407 says the tray did not lift. I would look at the flag/sensor in the tray first. On mine I tried another tray with harness first, but I was getting green light and motor was turning.
    • roho
      • Mar 2009
      • 844
      Had this once, lift doc tray up and look to the back of the tray, should see a white gear. Mine was cracked. Otherwise it could be a crimped wire or sensor. Check the white gear first though.
      • amitlama_78
        • Oct 2009
        • 62
        Thanks guys..... Will check today and update....
        • amitlama_78
          • Oct 2009
          • 62
          Hi
          checked the sensor.... light does not get turned on but on screen the finisher button gets highlighted.
          Is there anyway to turn the motor on and off from the service mode...
          I even checked the gears. All the gears are fine. could it be the motor?
          regards
          Amit Lama
          • amitlama_78
            • Oct 2009
            • 62
            hello
            Anyone could suggest what to look for?
            • dan7777
              • Dec 2012
              • 680
              hello
              Try changing the wire harness to the tray or move it around. You need the green light when a piece of paper is in the tray. I think the grey wires are smaller and purple bigger new style. Could be sensor but I doubt it.
              • amitlama_78
                • Oct 2009
                • 62
                Tried changing the wire but no luck
                • dan7777
                  • Dec 2012
                  • 680
                  I would be stuck trying to find out why the green light did not come on when the paper present sensor was pushed. On mine I did not figure it out but mine was turning the motor, green light coming on, and occasionally would lift. I looked and did not see where you could turn on m8 lift motor. sr13 (tray home position sensor), lift motor and main board dadf driver pcb all have to be good. The error code you had says the motor turned on but tray home position sensor did not change state.
                  reader c-1.pdf
                  There were a few tech pubs saying the springs were missing from the pick up roller assembly.
                  • roho
                    • Mar 2009
                    • 844
                    Has the error condition been resolved? If the device is still in error mode the sensor will never light. There are service modes under FEEDER to try various operations, check under feeder>function> and use the info key.
                    See if the device is still in error mode, check error history first.
                    • amitlama_78
                      • Oct 2009
                      • 62
                      Hi
                      Mine error is gone but motor does not lift.
                      If I lift the motor manual by gear the tray lifts.
                      And when I switch on the machine the tray goes down to it's home position..
                      Cant figure out the problem.
                      • amitlama_78
                        • Oct 2009
                        • 62
                        Hi
                        I checked everything and on service mode motor is running and even the sensor. Could it be the PCB board?
                        • roho
                          • Mar 2009
                          • 844
                          Hi
                          If those checks are correct then that would likely be the next thing. Those tests seem to rule out any wiring issue or component fault.
                          • amitlama_78
                            • Oct 2009
                            • 62
                            what should i look for now?
                            • roho
                              • Mar 2009
                              • 844
                              If the components check out then the controller PCB would be the next step.
