IR2010F continous message of:mixing toner:
  • axyun
    • Aug 2007
    • 1323
    Ir2010F message of "TONER MIXING" when machine is turned on. I wait several minutes for message to go away but it remains. The toner cartridge has plenty of toner. I am unfamiliar with this and have been unable to get r.eference manual as copying guide and service manual do not show this message. Is this a developer unit issue. Cusromer wants to knw what is involved before servicing as they have another machine and don't want to spend a lot fix this issue. Frank
  • copier tech
    • 8231
    Re: IR2010F continous message of:mixing toner:
    You can strip & clean the dev units on these old models however the best fix is to fit a new dev unit & toner.
    • axyun
      • Aug 2007
      • 1323
      thank you for your service copier tech
