Canon part question
  • copiman
    • Sep 2011
    • 861
    Canon part question
    I am new to the Canon product and trying to understand things. For those that have been around, I'm sure you know the answer.
    I'm looking at part # FM1-A719-010 ADF sep pad. I looked in ISG and chose old>new and got nothing. When I chose new>old I got 3 number
    FL3-5538-010
    FL3-5538-000
    FL2-9942-000
    I assume the release sequence of these were in this order:
    1st FL2-9942-000
    2nd FL3-5538-000
    3rd FL3-5538-010
    4th FM1-A719-010
    I am looking at these models: MODEL IR 1730, 1740, 1750 & IR ADV 400, 500
    I was told by someone to use FL3-5538-010 on all these models but I would think the latest FM1-A719-010 is the one to use, right?
    Any input you could give would be greatly appreciated.
    Thank you,
    Confused tech
  • Brian8506
    • 1665
    Re: Canon part question
    You are correct. The FM1-A719 is more coarse
      • 23009
      My guess is that regardless which number you order you'll get FM1-A719-010, and possibly a revised sticker over the number. =^..^=
      • copiman
        • Sep 2011
        • 861
        • Thanks Brian and Blackcat. I will use the one Canon says to use. I knew I could get the right scoop here.
