canon iradv 6065 error 000263-000
  • hamdyyassin
    • 84
    hi,i need help my copier canon iradv 6065 giving error 000263-000 i changed the ac driver and the main driver pcbs.
    i check the connectors but the error still present.
    thanks for help
  • teckat
    • 16083
    Re: canon iradv 6065 error 000263-000
    thanks for help
    Relay PCB (PCB 5) in the Power Cord Terminal Assembly
    Relay PCB is FM4-1086-000
    Main Driver PCB and the AC Driver PCB have been replaced.
    Tie wraps have been removed from the wire harness that plugs into J103 on the Main Driver PCB.
    Pin 3 of connector J101 on the Main Driver PCB is missing 12 VDC which comes from J515 of the Relay PCB. At pin 3 of J515 on the Relay PCB, 12 VDC is missing. At J511 of the Relay PCB, 12 VDC is present coming from the 12 Volt DC Power Supply.
    Refer to the following illustration:
    Solution :
    Pico fuse FU514 on the Relay PCB located under J515 was blown which interrupted 12 VDC to pin 3 for J515.
    Replacing the Relay PCB was the resolution for clearing out error code E263-0000 from the machine.
    • haniff12
      • Jul 2020
      • 9
      Is there a way to repair the board . i have erroe E263-000 as well
      • copier tech
        • 8169
        Yes, if you replace the Pico fuse FU514 on the Relay PCB!
        • teckat
          • 16083
          Have all of the pico fuses on the Main Driver PCB checked out good.
          Did u make these checks ?????
          • haniff12
            • Jul 2020
            • 9
            Thanks for the illustration. Can I get an email for the image . Abit pixelated.
            copycat.cp@gmail.com. Thanks for your help
            • teckat
              • 16083
