AdvC5235A E0225-0001
  • repeatcopiers
    • Sep 2008
    • 591
    Customer just purchased this AdvC5235A and it keeps throwing an E0225-0001, I don't see this code in the SM, any help?
    Sorry guys, miscommunication, this code is not on this copier, please disregard post!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5002
    Re: AdvC5235A E0225-0001
    Error 225 is usually scanner lamp.
    • copier tech
      • 8107
      You sure the code is correct?
      Sounds like a main counter mismatch error. 🧐
      • repeatcopiers
        • Sep 2008
        • 591
        Sorry I edited the post. The tech was giving me a code for an AdvC2020, not the C5235 I thought we were speaking about.
        • JPiek
          • Oct 2014
          • 435
          Then it obviously was a communication error
          Johan
          • Herrmann
            • Jan 2006
            • 792
            We are talking now about IRADVC 2025, right?
            If I remember correctly, there was a Bulletin about a faulty Power Supply, causing several errors. Maybe you should give it a try
            If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
            • JPiek
              • Oct 2014
              • 435
              Zoraldinho is right, it's a Scanner lamp/ Scanner light error, jut not on the 52xx
              Johan
