Advance C250if drum counter
  • guitar9199
    • Sep 2016
    • 1100
    #16
    Re: Advance C250if drum counter
    Originally posted by campy
    Here are the counters. Is it telling me the amount used or the amount left?[ATTACH=CONFIG]40658[/ATTACH][ATTACH=CONFIG]40657[/ATTACH]
    I see the problem.... In the right column, "Expected Life" is set to zero. If I remember correctly, that part is rated for either 150K or 500K.
    (It's been a while since I looked those up.) If you change the Life column to 150000, the remaining life percentage will change.
