canon ir 3300 e 51 error
  • pradee94
    • Jul 2017
    • 15
    [Error Code] canon ir 3300 e 51 error
    gear
  • copier tech
    • 8144
    Re: canon ir 3300 e 51 error
    Originally posted by pradee94
    gear
    Replace the motor it comes with the small gear, these crack over time part number FH6-1253-000
    Code
    E051-0000
    Description
    At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position
    Causes
    The horizontal home position sensor is faulty. The horizontal registration motor is faulty. The DC controller PCB is faulty.
