imageRUNNER compatible toner damage
  • kserritt
    • Jun 2025
    We have an imageRUNNER Advance C3530i copier that someone installed a cyan remanufactured toner cartridge in. After printing a few pages we noticed it had some cyan streaks on the pages. The copier repair company came and said the toner damaged the copier. They replaced all 4 of the developer units and installed new toner cartridge. They said they had to clean out all the damaged toner. Is it possible that bad toner would have caused all 4 developer units to have to be replaced? Has anyone ever seen this before?
  • copier tech
    • 8133
    Re: imageRUNNER compatible toner damage
    Absolutely correct, compatible toner can vary dramatically in quality & cause all kind of issues.
    However if there was only compatible cyan toner fitted I would only expect the cyan dev unit & possibly drum to need repacing not the remaining colour dev units.
    • guitar9199
      • Sep 2016
      • 1100
      I would also take a good hard look at the transfer belt, cleaning blade and transfer roller as well. Some aftermarket toner is so abrasive, it'll wear those parts out too.
      • teckat
        • 16083
        U probably got ripped off with having to replace the other 3 units.
        Pays to always get a second option,
        By the way, if u had a service contract, that would be a violation of agreement using third-party.
        Agree that the ITB and some other parts could have been effected.
