Canon IR C5235i
  • ecnereht
    • Sep 2018
    • 40
    Canon IR C5235i
    Hi,
    Please help me with our printer having Error: E000840-000. Having noise also inside.
    Thanks!
    TSL
  • copier tech
    • 8136
    Re: Canon IR C5235i
    Originally posted by ecnereht
    Hi,
    Thanks!
    TSL
    Code
    E840-0000
    Description
    Error in shutter for Fixing Edge Cooling Fan (if the HP failed to be detected when the error occurred).
    Failed to detect that the fan shutter has moved to the specified position when moving the fan shutter from anywhere other than the HP.
    Remedy
    1. Check the harness of the Shutter Motor (M27), the Shutter HP Sensor (PS31) and the Shutter Position Sensor (PS32) (to see if the harness is caught, disconnected or physically removed). 2. Replace the Pickup Feed Driver PCB (UN2). 3. Replace the Shutter Motor, the Shutter HP Sensor or the Shutter Position Sensor.
    • ecnereht
      • Sep 2018
      • 40
      Re: Canon IR C5235i
      Thanks I will do that once I get to the site.
      • tech28
        • Jun 2013
        • 434
        Re: Canon IR C5235i
        Take a fuser with you if you have another one. Save you a lot of time.
