First you need to check if scan board is installed.If answer is yes then go to service mode and turn on.If answer is no...
Level 2
COPIER>OPTION>BODY>UI-SEND
0: Don't display
1: Display
Practice makes perfect
If you want something done right, you have to do it yourself
Check all the pages. Maybe someone moved it to another page. We move the scanner, ifax and others to pages you can not see. If it is not anywhere then if it were me I would reinstall software, overwrite all. I am guessing it is just moved.
