No Scan Button on the touch panel
  • gtr5320
    • Dec 2016
    • 32
    C5235 No Scan Button on the touch panel?
    What should I do?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: No Scan Button on the touch panel
    First you need to check if scan board is installed.If answer is yes then go to service mode and turn on.If answer is no...
    Level 2
    COPIER>OPTION>BODY>UI-SEND
    0: Don't display
    1: Display
    • dan7777
      • Dec 2012
      • 680
      What should I do?
      Check all the pages. Maybe someone moved it to another page. We move the scanner, ifax and others to pages you can not see. If it is not anywhere then if it were me I would reinstall software, overwrite all. I am guessing it is just moved.
      • gtr5320
        • Dec 2016
        • 32
        WEB has seen the address book
        • gtr5320
          • Dec 2016
          • 32
          Level 2
          0: Don't display
          1: Display
          this is correct
          Display 1
