IR-330
  • T911
    • Jun 2007
    • 628
    IR-330
    i can't get an original through this df. stops right after the reg switch everytime. cl-reg switch, eye and black mylars in addition to the obvious feed rollers in the system along with the belts. i went back and swapped this feeder with another but exactly the same problem. any ideas appreciated. thanks t
    • 23003
    What type of DF? DADF-A1 or DADF-B1? Jam codes?
    • T911
      • Jun 2007
      • 628
      do not have the model number of the df, but its the one that shoots the originals to the righgt catch tray. looks exactly like the one on older models. thanks t
        • 23003
        If it looks like the RADF-G1 on the GP200/iR210 its a DADF-A1.
        What jam codes?
        • costd
          • Jan 2008
          • 409
          If the exit tray is on the right, I suspect it is a B1. Not technical, but take a look at it: if it feeds from the left and only has the one "lump" it is an A1. If it has a 2nd "lump" on the right it is a B1.
          In either case, the jam code would be nice to have. A real SWAG (since you said you switched the complete feeder unit is (if it is a B1) the exit tray alignment. Other than that (again if you did switch out the complete unit) it has to be a control board.
          Again, an error code would help.
          BTW: Since you are a tech, the Canon e-support site, parts, has a box you may enter the 3 letters of the serial number and it will tell you the model.
